Seite 3 von 6
Re: Download Link für PC PSO und PSOBB
Verfasst: 03 Mai 2008, 11:37
von Wiegand
Also wir haben einen Router/Firewall glaub ich(t-online???-Eumex 800v)
dieser sperrt von anfang an alle TCP-ports.
Auf der Blue-Burst page steht folgendes:
The TCP port numbers are 11000, 11001, 11100, 11101 and 12000 ~ 12010.
bedeutet : 12000 ~ 12010, dass man alle von 12000 'bis' 12010 freigeben muss?oder nur einen davon.
Also ich hab jetzt freigegeben: 11000 11001 11100 11101 und 12000
ich kriegs nich hin mit dem pic-upload...
Verfasst: 03 Mai 2008, 15:07
Following June 13's maintenance, new port ranges will need to be applied to your Firewall. The ranges are listed below:
TCP port- 11000, 11001, 12000 - 12040
There will be a website update shortly to correct these values in our troubleshooting thread. Please be aware and make the neccesarry changes.
Thanks!
http://boards2.sega.com/psobb_board/vie ... hp?t=64636
ob dieses auch auf dem Privat Server zutrift kann ich dir nicht sagen.
21Cannot transfer to a certain SHIP, or the SHIP does not display. Possible issue: Router is blocking TCP port
Your broadband router may be blocking the TCP port for the patch download server. The TCP port numbers are 11000, 11001, 11100, 11101 and 12000 ~ 12010. You may have to change your router settings to allow access to these ports. For information on how to do this, please consult your router's instruction manual.
23Notice- Nforce3 and Nforce4 Motherboards. Possible issue: Supplemental Language Support is Enabled
There is a known issue concerning onboard network card for nForce3 and nForce4 motherboards. If you own one of these motherboards and are experiencing trouble getting to the character select screen, please follow the steps below to resolve the issue.
1. Open Control Panel
2. Open System
3. Select the Hardware tab
4. Select Device Manager
5. A window will appear with a list of devices, click the + symbol next to
Network Adaptors
6. Right Click the Nvidia nForce Network card and select Properties
7. Choose the Advanced tab
8. Select Checksum Offload
9. Set the Value to Disable
http://www.psobb.com/support/images/nforce_screen.jpg
Verfasst: 03 Mai 2008, 16:44
von Wiegand
Verfasst: 04 Mai 2008, 13:53
Glaube nur die einzelnen welchen Router hast du den überhaupt ?
Verfasst: 04 Mai 2008, 16:03
von Wiegand
Eumex 800v...
Verfasst: 04 Mai 2008, 18:26
Wiegand hat geschrieben:Eumex 800v...
Das ist ein Modem und kein Router oder ?
http://www.telekom.de/Katalog_GK_Eumex% ... EPf7Rq1oCQ
Kannst du einmal ein Bild machen mithilfe der taste Druck rechts oben neben F12 und in Paint einfügen sowie das Bild wo hochladen und hier reingeben. Ich finde einfach nichts über diesen Fehler an.
Auser uns selber.
http://www.google.de/search?hl=de&sa=X& ... 00&spell=1
Verfasst: 06 Mai 2008, 18:14
Stand das in deiner Originalquelle auch mit "~" ?
Wenn es mit "-" Angegeben steht heißt das immer von bis. Und einzelne Ports werden mit Kommata getrennt.
Deshalb nehm ich an, dass du alle in dem Bereich freigeben musst.
Bei den meisten Routern kannst du das ja mit XXX - XXX machen, also musst du nicht alle einzeln freigeben ;-)
Verfasst: 10 Mai 2008, 19:59
von Tidus0607
also ich habe PSo vor 3-4 jahre ständig auf der GAme Cube gezockt als ich jedoch das spiel verloren habe habe ich damit aufgehört und jetz habe ich gelesen das man es downloaden kan aber auf der oficiellen seite gehts net deswegen habe ich es hier versucht aber jetz zu mein problem ich bitte um hilfe :
ich habe CD 1 und CD2 gedownloadet und entpackt jetz steht da instalieren! aber der kan nicht instalieren er fragt mit was ich öffnen sol?!
2. habe mal die patche gedownloadet ohne zu instalieren und dan dopelklick draufgemacht dan komemn nur fragezeichen und paar button und wen ich ganz oben draufklicke kommt das "This section as been closed beacause to mutch player have registered a shared serial. Registering a serial give you an unic Guild Card number but if done on a shared serial that make all player using this serial chating trought the same chat bubble, receive the same mail also save on your char backup. "
ich wil das spiel unbedingt spielen ich flehe um bitte xD
BITTE^^
Verfasst: 10 Mai 2008, 20:11
Es kommt sicherlich die Fehlermledung no Support Language
Start/Arbeitsplatz/CD Rom Laufwerk und such die Setup.exe auf der CD danach sollte die Installation Starten.
Verfasst: 10 Mai 2008, 20:22
von Tidus0607
welche cd sry habe ich jetz irgentwas verpasst ich verstehe echt null aber bitte nicht aufgeben mir zu helfen xD ich würds echt gerne wieder zocken
ja die fehlermeldung komtm auch aber ich habe ja nichs instaliert wa smus ich machen beide cds entpacken dan den patch und wo dan draufklicken?>< bitte eine genauere einleitung nimmd ir bitte die zeit ich bitte dich darum
