Download Link für PC PSO und PSOBB
für den PC
Bevor du spielst PHANTASY STAR ONLINE PC PSO die Systemanforderung
System Requirements
In order to play PHANTASY STAR ONLINE, your computer needs to meet the following system requirements. The game may not run on computers that do not fulfill these specifications.
Mimimum Requirements :
Operating System : Windows 98/Me/2000/XP with DirectX 8.1 or higher
CPU : Pentium III (or compatible) 450 MHz
RAM : 64MB
Hard Drive Space : 600MB or greater (Minimum Install with Custom Setting)
CD-ROM Drive : 4X or faster
Video Card : DirectX certified video card with at least 8 MB of video RAM
Sound Card : DirectX certified sound card
Keyboard, Mouse
Note : Additional Hard Drive space may be required when installing software update patches.
Recommended :
CPU : Pentium III (or compatible) 700MHz or faster
RAM : 128MB or greater
Hard Drive Space : 1.3 GB or greater
CD-ROM Drive : 8X or faster
Video Card : DirectX certified video card with 16 MB of video RAM or greater
Game Control Pad with 6 or more buttons (Microsoft SideWinder GAME PAD PRO recommended)
Note : Performance will vary according to your computer's hardware specifications, especially the type of video card you use. PHANTASY STAR ONLINE will achieve better performance on high-performance computers.
Improved Graphical Effects :
By setting the graphics configuration on "High-End" via the options window, you will be able to play PHANTASY STAR ONLINE with improved Technique (magic spell) effects and background graphics. We recommend using this setting only on a high performance system (Pentium4 1.4GHz or faster) with a high RAM-capacity video card.
In-game slowdowns have been known to occur when running PHANTASY STAR ONLINE on "High-End" setting - possible causes are video card-specific limitations including yet not limited to lack of video RAM. We recommend playing on "Normal" or "Low-End" setting if this happens, depending on the overall performance of your computer.
http://www.psopc.net//pc/pso/download/game/
Username:psopc
Password:psopcnet
Nachdem ihr das Spiel Installiert haben ladet euch auch noch da wo ihr die 2 CD herunderladen habt vom oberen Link die rar. Datei patch herunter und überschreibt alle Dateien mit den neuen. Danach haltet auch an Clows Tipp weiter unten wie ihr euch einen Serial,Key macht damit ihr auch Musik in der Lobby sowie Guild Cards euch schreiben könnt.
Zuletzt geändert von Nir am 04 Jun 2008, 14:29, insgesamt 11-mal geändert.
1. Befor du spielst PSOBB US hier die Systemanforderungen lese sie dir genau durch
Compliant Graphics Cards
In order to run Graphics Settings at Normal or Above, you must have one of the following:[/stile]
NVIDIA GeForce FX 5200/5600/5900, GeForce4Ti4200, GeForce3/3Ti200/3Ti500
ATi RADEON 8500/8500LE/9600PRO/9800PRO
[stile]In order to run Graphics Settings at Low-End, you must have one of the following:[/stile]
NVIDIA GeForce2 MX400/GTS/Ti, GeForce256, RIVA TNT2
ATi RADEON 7000(VE)/7200(SDR,DDR,LE)/7500, Rage 128PRO (*)
SiS SIS315/SIS740, Intel i845G/i845GL
Matrox Millennium G400/Millennium G550 (*)
* Only when running Windows2000/XP
[hr][/hr]
2. System Requirements
Required
OS Windows 98/2000/XP/Me
CPU Pentium III 700 MHz
Graphics  3D graphics board,
minimum 32 MB VRAM
(Direct 3D, NVIDIA GeForce 3,
ATI Radeon 8500)
Sound DirectSound compatible sound card
DirectX DirectX 9.0b
Free Disk Space  1.5GB minimum (may change based on patches)
Network 256kbps internet connection
Recommended
OS  Windows XP
CPU Pentium4 1.4GHz or higher
Memory  256 MB
64 MB VRAM
ATI Radeon 8500)
Download PSOBB US Version mit allen Updates
http://www.psopc.net/pc/psobb/download/game/
Username:psobb
Passwort: psopcnet
Japan Patch
http://www.psopc.net/community/viewtopic.php?f=3&t=1215
benutzt den Japan patch nur wenn ihr wisst wie man mit global IME umgeht das heist ihr müßt eure tastatur auf English umstellen oder auf Japanisch da ihr sonst nicht schreiben könnt.
Zuletzt geändert von Nir am 04 Jun 2008, 14:44, insgesamt 2-mal geändert.
Edit
Ihr müsst sogar jetzt den Japan Patch benutzen sofern ihr PSOBB spielen wollt diesen bekommt ihr hier.
http://www.psopc.net/forum/download2/jp-en.rar
Zuletzt geändert von Nir am 29 Aug 2008, 22:35, insgesamt 2-mal geändert.
Inferno
Re:
Beitrag von Inferno »
Hay Nir wenn ich das Runterladen möchte kommt das eingabe feld.
Wenn ich da alles eingeb kommt das Fenster wieder und ich kann nichts runterladen...
Name und Pass ist doch planetpsu.net und xhk7y?
Re: Download Link für PC PSO und PSOBB
Wurde geändert sollte wieder gehen.
Inferno
Nir hat geschrieben:Wurde geändert sollte wieder gehen.
Ne immernoch nicht habs mit Firefox und Inet explorer getestet irgentwie fragt der immer wieder nach pass und name.....
Und das neue Password steht oben für die Version die du haben möchtest.
Es wurde ein neues genohmen weil andere Seiten dieses auch benutzt haben ohne mich zu fragen.
lösche mal die Passwörter im Internet Explorer danach neues reinschreiben und es sollte gehen.
Inferno
Nir hat geschrieben:Und das neue Password steht oben für die Version die du haben möchtest.
Ah jetzt gehts :) danke :D
Edit: Sofern ihr PSO für den PC herundergeladen habt ladet euch auch noch den unteren patch herunder danach ladet euch dieses Datei herunder.
SCHTHACK Launcher
http://www.schtserv.com/reg.zip
Danach haltet euch an das was Clow im unterem als Antwort gibt.
Zuletzt geändert von Nir am 03 Mär 2008, 08:16, insgesamt 1-mal geändert.
Inferno
Hab heut PsoBB und PsoPC gezoggt und alles hat bestens gefunzt also cih hatte diese Meldung noch nciht :)
